Multi-criteria analysis for locating new urban forests; An example from Isparta, Turkey
Atila Gül (A), Abdullah Gezer(B) , Brian Kane©
A: Department of Landscape Architecture, Süleyman Demirel University, Turkey
B: Department of Forest Engineering, Faculty of Forestry, Süleyman Demirel University, Turkey
C:Department of Natural Resources Conservation, 160 Holdsworth Way, University of Massachusetts, Amherst, MA 01003, USA
Abstract
The concept of the urban forest is new for Turkey. Since many areas of Turkey are rapidly converting to urban and suburban landscapes, maintaining existing greenspace or creating new greenspace is important. Multi-criteria analysis(MCA) was used to determine the most suitable area for creating new urban forest in Isparta, Turkey, employing the approach used in Ghent, Belgium (Van Elegem et al., 2002. A methodology to select the best locations for new urban forests using multi-criteria analysis. Forestry 75, 13–22.). There are three stages in the MCA, the initial selection stage, the suitability stage, and the feasibility stage. In each stage, potential areas are evaluated according to several criteria. In the suitability stage, criteria are grouped according to three themes of the urban forest profile, recreational, ecological, and structure strengthening.
The recreational theme was weighted more heavily than the others because surveys had shown this to be an important consideration for residents and greenspace management experts in Isparta. A sensitivity analysis did not show any change in the overall results as a consequence of the weighting. The two areas most appropriate for the creation of new urban forest in Isparta received high scores in the recreational theme due to their proximity to the city center.
The flexibility of MCA was useful in adjusting criteria in each stage to adapt to contextual changes in Isparta. The flexibility of MCA should also expedite its application for other communities interested in creating new areas of urban forest. Application in other communities will probably require changing criteria, sub-criteria, and indicators according to local conditions and priorities. Input from local stakeholders facilitated the MCA and was likely an important reason that the results of the MCA were enthusiastically received by local officials and planners.
تجزیه و تحلیل چند معیاره برای مکانیابی جنگل های شهری جدید : به عنوان مثال در اسپارتا، ترکیه
Atila Gül, Abdullah Gezer, Brian Kane
A: گروه معماری منظر، دانشگاه سلیمان دمیرل ترکیه
B: گروه فنی و مهندسی جنگل، دانشکده جنگلداری، دانشگاه سلیمان دمیرل ترکیه
C: گروه حفاظت از منابع طبیعی، 160 Holdsworth راه، دانشگاه ماساچوست امهرست، MA 01003، ایالات متحده آمریکا
چکیده
مفهوم جنگل شهری برای ترکیه جدید است. از آنجایی که مناظر بیشتر مناطق ترکیه به سرعت در حال تبدیل شدن به شکل شهری و حومه شهری شدن هستند، حفظ فضای سبز موجود و یا ایجاد فضاهای سبز جدید دارای اهمیت است. برای تعیین مناسب ترین منطقه برای ایجاد جنگل های شهری جدید در اسپارتا در ترکیه، از رویکرد مورد استفاده در مطالعه گنت بلژیک که تجزیه و تحلیل چند معیاره (MCA) بود، استفاده شد. (Van Elegem et al., 2002. A methodology to select the best locations for new urban forests using multi-criteria analysis. Forestry 75, 13–22.). سه مرحله در MCA وجود دارد،که شامل مرحله انتخاب اولیه،مرحله شایستگی، و مرحله امکان سنجی می شود. در هر مرحله، مناطق بالقوه با توجه به معیارهای مختلف ارزیابی می شوند. در مرحله شایستگی، معیار با توجه به سه موضوع از مشخصات جنگل شهری( تفریحی، اکولوژیکی، و تقویت ساختار) گروه بندی می شود.
موضوع تفریحی از لحاظ وزنی به شدت از سایر موارد سنگینی می کرد، زیرا بررسی ها نشان داده است این مورد برای ساکنان و کارشناسان مدیریت فضای سبز در اسپارتا به طور مهم مورد توجه قرار گرفته است.تجزیه و تحلیل حساسیت هر گونه تغییر در نتایج کلی به عنوان نتیجه ای از وزن دهی نشان نمی دهد. دو منطقه در موضوع تفریحی برای ایجاد جنگل های شهری جدید در اسپارتا، از بابت نمرات بالای دریافتی با توجه به نزدیکی به مرکز شهر، مناسب ترین می باشد .
انعطاف پذیری روش MCA برای تنظیم و تعدیل معیارها در هر مرحله به منظور انطباق با تغییرات متنی در اسپارتا، مفید واقع شد. انعطاف پذیری MCA نیز باید کاربردهای آن برای سایر جوامع علاقه مند به ایجاد جنگل های شهری جید را تسریع ببخشد. کاربرد در جوامع دیگر احتمالا با توجه به شرایط و اولویت های محلی نیاز به تغییر در معیارها، زیر معیارها، و شاخص ها دارد. اطلاعات ورودی حاصل از ذینفعان محلی انجام MCA را تسهیل بخشید و احتمالا این یک دلیل مهم است که نتایج MCA با شوق و ذوق توسط مقامات و برنامه ریزان محلی مورد استقبال قرار گرفت .
دانلود به فرمت PDF
دانلود به فرمت Word
ترجمه کامل فارسی مقاله:
[h=2]Multi-criteria analysis for locating new urban forests; An example from Isparta, Turkey[/h]ترجمه و ویرایش:قاسم زارع
دانلود به فرمت PDF:
