soheiiil 24253 ارسال شده در 2 آذر، 2013 مجموعه عالی از پایان نامه های انگلیسی مهندسی مکانیک گرایش ساخت و تولید - سیالات - جامدات عناوین: A biomechanical invesitgation of the surface stress of a syntheti A consignment stock policy for a two-level supply chain with imperfect quality items A dual factor decision making model in green manufacturing A production-recycling-reuse model for plastic beverages bottles A Study on Radial and Axial Temperature Effects on the Growth of Bulk Single Crystal of SixGe1-x in Bridgman Setting Abrasive jet micro-machining of metals An empirical application of data envelopment analysis in credit rating Assessment of an acoustic chamber for testing structure-borne sound transmission in a doublepanel assembly Chaotic time series forecasting with residual analysis using SYNERGY OF ENSEMBLE NEURAL NETWORKS Compaction density variation in powder metallurgy components Cryogenic Abrasive Jet Machining of Polydimethylsiloxane and Polytetrafluoroethylene Development of a micromirror based laster vector scanning automot HUD Development of a novel automated micro-assembly mechanism Development of personalized online systems for web search recommerce Effect of grain refinement on the microstructure dendrite coherency and porosity of AZ91E Effect of micro vibration from two space platform on liquid mixture during thermodiffusion EOQ models for deteriorating items with two levels of market Evaluating the Performance of Two Solar Domestic Hot Water System Experimental implementation of artificial neural network-based active vibration control & chatter suppression Fabrication of microfluidic channels via Two Photon Absorption (TPA) polymerization Finite element analysis of a single conductor with a Stockbridge damper under Aeolian vibration Finite element analysis of knee articular cartilage Fractal fluctuations in the cardiovascular dynamical system - from the autonomic control to the central nervous system influence Inventory control in a two-level supply chain with learning quality and inspection errors Laser induced reverse transfer for microfabrication Laser shadowgraphy measurement of abrasive particle mass, size and velocity distributions through micro-masks used in abrasive jet micromachining Least Cost Analysis of Energy Efficiency Upgrades for Ontario Using Trnsys Minimizing makespan of a flexible machine under tooling contraint Modeling of advanced fossil fuel power plants Modelling surface evolution in abrasive jet micromachining using level set methods Modification and integration of shear thickening fluids into high performance fabrics Novel grain refinement of AZ91E magnesium alloy and the effect on hot tearing during solidfication Numerical and experimental investigations on vibration of simulated CANDU fuel bundles Optimal inventory policy for the two-level supply chain with defective items Performance analysis of a two-stage variable capacity air source heat pump and a horizontal loop coupled ground source heat pump system Preliminary Analysis of the Effects of Different Machining Techniques on Carbon Fibre Epoxy Materials Probabilistic learning curve and real options approach to the Valuation of Cross-Training Shoe embedded air pump type piezoelectric power harvester Solid particle erosion of materials for use in gas pipeline control Surface roughness estimation for FDM systems The effect of temperature on fatigue strength and damage of FRP composite laminates The Integration of Human Factors into Discrete Event Simulation and Technology Acceptance پارت اول برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام پارت دوم برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام پارت سوم پارت چهارم برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام پارت پنجم برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام پارت ششم pass : mechanicspa.mihanblog.com منبع : برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام 5
