Hubble Sees a Unique Cluster: One of the Hidden 15
Credit: ESA/NASA, Hubble
Palomar 2 is part of a group of 15 globulars known as the Palomar clusters. These clusters, as the name suggests, were discovered in survey plates from the first Palomar Observatory Sky Survey in the 1950s, a project that involved some of the most well-known astronomers of the day, including Edwin Hubble. They were discovered quite late because they are so faint -- each is either extremely remote, very heavily hidden behind blankets of dust, or has a very small number of remaining stars.
This particular cluster is unique in more than one way. For one, it is the only globular cluster that we see in this part of the sky, the northern constellation of Auriga (The Charioteer). Globular clusters orbit the center of a galaxy like the Milky Way in the same way that satellites circle around the Earth. This means that they normally lie closer in to the galactic center than we do, and so we almost always see them in the same region of the sky. Palomar 2 is an exception to this, as it is around five times further away from the center of the Milky Way than other clusters. It also lies in the opposite direction -- further out than Earth -- and so it is classed as an "outer halo" globular.
It is also unusual due to its apparent dimness. The cluster is veiled by a mask of dust, dampening the apparent brightness of the stars within it and making it appear as a very faint burst of stars. The stunning NASA/ESA Hubble Space Telescope image shows Palomar 2 in a way that could not be captured from smaller or ground-based telescopes -- some amateur astronomers with large telescopes attempt to observe all of the obscure and well-hidden Palomar 15 as a challenge, to see how many they can pick out from the starry sky.
European Space Agency
