M!Zare 48040 ارسال شده در 27 آذر، 2011 In thermodynamics, the exergy of a system is the maximum useful work possible during a process that brings the system into equilibrium with a heat reservoir . When the surroundings are the reservoir, exergy is the potential of a system to cause a change as it achieves equilibrium with its environment. Exergy is the energy that is available to be used. After the system and surroundings reach equilibrium, the exergy is zero. Determining exergy was also the first goal of thermodynamics 2
M!Zare 48040 مالک ارسال شده در 27 آذر، 2011 Energy is never destroyed during a process; it changes from one form to another. In contrast, exergy accounts for the irreversibility of a process due to increase in entropy . Exergy is always destroyed when a process involves a temperature change. This destruction is proportional to the entropy increase of the system together with its surroundings. The destroyed exergy has been called anergy. For an isothermal process exergy and energy are interchangeable terms, and there is no anergy
M!Zare 48040 مالک ارسال شده در 30 آذر، 2011 Exergy analysis is performed in the field of industrial ecology to use energy more efficiently. The term was coined by Zoran Rant in 1956, but the concept was developed by J.Willard Gibbs in 1873. Ecologists and design engineers often choose a reference state for the reservoir that may be different from the actual surroundings of the system.Exergy is a combination property of a system and its environment because unlike energy it depends on the state of both the system and environment. The exergy of a system in equilibrium with the environment is zero. Exergy is neither a thermodynamic property of matter nor a thermodynamic potential of a system. Exergy and energy both have units of joules. The Internal Energy of a system is always measured from a fixed reference state and is therefore always a state function. Some authors define the exergy of the system to be changed when the environment changes, in which case it is not a state function. Other writers prefer a slightly alternate definition of the available energy or exergy of a system where the environment is firmly defined, as an unchangeable absolute reference state, and in this alternate definition exergy becomes a property of the state of the system alone 1
