سارا-افشار 36437 ارسال شده در 22 آبان، 2011 In this tutorial we will show you how to install Windows XP inside Windows Vista using Microsoft Virtual PC. Requirements: ?. Windows XP CD ?. Microsoft Virtual PC ?. One hour free time Procedure: 1. Download and install Virtual PC from برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام 2. Run the Virtual PC software. To do this, type Virtual PC in Vista Start menu search box and hit enter. 3. Click on “New” option and click “Next” to continue. 4. Select “Create a virtual machine” option from the available three options. I prefer this option as this lets you customize as you like. Click “Next”. 5. Here, type a name for the virtual machine file. The file is automatically saved to the My Virtual Machines folder. To save it to a different location, use the “Browse” button. 6. Select the operating system you would like to install using Virtual PC from the drop down box.In this tutorial we choose XP, as we are going to install none other than XP. After selecting the operating system, click “Next”. 7. If you have more than 1GB of RAM in your system, select “Adjusting the RAM” else select “Using the recommended RAM”. If you have chosen “Adjusting the RAM” then, select the amount of RAM you would like to allocate to run Virtual machine(XP) and click “Next”. (by default, it will use 128MB of RAM, if you like to keep as it is, blindly click “Next”) 8. In the next screen, select “A new virtual hard disk” and once again “click” button. 9. In this step, browse the location where you want to create a virtual hard disk and specify a name for the virtual hard drive. Also don’t forget to specify the size of the Virtual Hard Drive. I prefer at least 3GB. 10. Click on finish button. 11. This will open a small window called “Virtual PC Console”. Click on “Start” button to start the actual process. 12. Insert your Windows XP CD the optical drive and hit enter when Virtual PC console prompts this window. (No need to restart your system. System will be restarted within the console.) You will see default XP installing environment inside the console. 13. Install the XP inside the console with the default XP procedure that you know. Once you finished your installation you will see this Window. 14. Now, you can install all the required software’s for your Windows XP. 15. You can close the Virtual PC with a simple click on the “close”(top right) button. 16. To open your Virtual XP once again, type “Virtual PC”(without quotes) in the Start menu and select the your Virtual XP from the box and click “Start”. 17. You are done!! 18. Enjoy!!! 5
soheiiil 24252 ارسال شده در 22 آبان، 2011 یه برنامه بود اسمش الان خاطرم نیست تو محیط سون یا ویستا اجراش میکردی و بدون تنظیمات میرفتی تو محیط ایکس پی 32 یا 64 بیتی 3
842 ارسال شده در 22 آبان، 2011 یه برنامه بود اسمش الان خاطرم نیست تو محیط سون یا ویستا اجراش میکردی و بدون تنظیمات میرفتی تو محیط ایکس پی 32 یا 64 بیتی آپدیت Windows XP Mode 3
سارا-افشار 36437 مالک ارسال شده در 22 آبان، 2011 آپدیت Windows XP Mode این محیط کاری xp رو شبیه سازی می کنه یا کلا مثل مد ms dos که یه زمونی تو محیط ویندوز 98 بود کار می کنه ؟ 2
842 ارسال شده در 22 آبان، 2011 این محیط کاری xp رو شبیه سازی می کنه یا کلا مثل مد ms dos که یه زمونی تو محیط ویندوز 98 بود کار می کنه ؟ وقتی این آپدیت رو روی ویندوز 7 نصب کنید (حجمش 400 مگه فکر کنم)، Windows Virtual PC روی ویندوز نصب میشه و مکمل همدیگه هستن. من خودم از VMware استفاده می کنم، اما جدیدا دیگه می خوام به VirtualBox مهاجرت کنم. او msdos یا Command مثل Shell لینوکس هستش که در همه ویندوز ها وجود داره و الان به صورت پیشرفته تر میتونید از PowerShell استفاده کنید. یک توضیح مقدماتی در باره پاور شل در این لینک داده شده: برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام 3
سارا-افشار 36437 مالک ارسال شده در 22 آبان، 2011 وقتی این آپدیت رو روی ویندوز 7 نصب کنید (حجمش 400 مگه فکر کنم)، Windows Virtual PC روی ویندوز نصب میشه و مکمل همدیگه هستن. من خودم از VMware استفاده می کنم، اما جدیدا دیگه می خوام به VirtualBox مهاجرت کنم. او msdos یا Command مثل Shell لینوکس هستش که در همه ویندوز ها وجود داره و الان به صورت پیشرفته تر میتونید از PowerShell استفاده کنید. یک توضیح مقدماتی در باره پاور شل در این لینک داده شده: برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام خب این VirtualBox چه مزیت هایی به VMware داره؟ 2
Nightingale 10531 ارسال شده در 22 آبان، 2011 من امروز سعی کردم با vmware مک نصب کنم ارور داد بستمش ! 3
842 ارسال شده در 22 آبان، 2011 خب این VirtualBox چه مزیت هایی به VMware داره؟ مزیت اصلیش OpenSource بودنش هست. و اینکه رایگانه. بعد هم اینکه از سیستم عامل های بیشتری نسبت به بقیه پشتیبانی میکنه. و دلیل بعدی اینکه سبکه! حجمش به 80 مگ هم نمیرسه(VMware 500 مگ هستش) سرعت بوتش هم خوبه. مقایسه VirtualBox رو با بقیه VMها : برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام البته VMware قابلیت ها و انعطاف پذیری زیادی داره مثل کپی کردن فایل از Host و پیست کردن اون در سیستم عامل ماشین مجازی. و یا درگ دروپ کردن. در کل برای من، VirtualBox گزینه بهتری هستش. 4
سارا-افشار 36437 مالک ارسال شده در 22 آبان، 2011 من امروز سعی کردم با vmware مک نصب کنم ارور داد بستمش ! کجاش error داد بگو تا با کمک هم حلش کنیم 2
Nightingale 10531 ارسال شده در 22 آبان، 2011 کجاش error داد بگو تا با کمک هم حلش کنیم مشکل سخت افزار نسخه مک lion بود که فقط برای سی پیوی اینتل هست مال منAMD هستش 2
842 ارسال شده در 22 آبان، 2011 مشکل سخت افزار نسخه مک lion بود که فقط برای سی پیوی اینتل هست مال منAMD هستش خوب Processorتون رو به AMD تبدیل کنید 4
Nightingale 10531 ارسال شده در 22 آبان، 2011 خوب Processorتون رو به AMD تبدیل کنید نمیشه فقط اینتل رو داره این نسخه مک دیدمش که عوضش کنم نمیشه 3
842 ارسال شده در 22 آبان، 2011 نمیشه فقط اینتل رو داره این نسخه مک دیدمش که عوضش کنم نمیشه مگه ميشه، نسخه vmشما چنده مگه؟ يعني تو ليست پروسسورهاتون amd رو نميبينيد؟ 3
Nightingale 10531 ارسال شده در 23 آبان، 2011 مگه ميشه، نسخه vmشما چنده مگه؟ يعني تو ليست پروسسورهاتون amd رو نميبينيد؟ آخرین ورژن نه نمیبینم میگم که زمانی تو اون لیست AMD رو نشون میده که خود OS ساپورت کنه این نسخه مک هک شده برای فقط اختصاصیه اینتل هستش برای همینم نشون نمیده سایر گزینه های که اتومات باشه پاسخ نمیده 2
