E-books
Fault Calculations
Introduction
Three phase fault calculations
Symmetrical component analysis of a three-phase network
Equations and network connections for various types of faults
Current and voltage distribution in a system due to a fault
Effect of system earthing on zero sequence quantities
References
Equivalent Circuits and Parameters of Power System Plant
Introduction
Synchronous machines
Armature reaction
Steady state theory
Salient pole rotor
Transient analysis
Asymmetry
Machine reactances
Negative sequence reactance
Zero sequence reactance
Direct and quadrature axis values
Effect of saturation on machine reactances
Transformers
Transformer positive sequence equivalent circuits
Transformer zero sequence equivalent circuits
Auto-transformers
Transformer impedances
Overhead lines and cables
Calculation of series impedance
Calculation of shunt impedance
Overhead line circuits with or without earth wires
OHL equivalent circuits
Cable circuits
Overhead line and cable data
References
Protection : Signalling and Intertripping
Introduction
Unit protection schemes
Teleprotection commands
Intertripping
Performance requirements
Transmission media, interference and noise
Methods of signalling
Overcurrent Protection for Phase and Earth Faults
Introduction
Co-ordination procedure
Principles of time/current grading
Standard I.D.M.T. overcurrent relays Combined I.D.M.T. and high set
instantaneous overcurrent relays
Very Inverse overcurrent relays
Extremely Inverse overcurrent relays
Other relay characteristics
Independent (definite) time overcurrent relays
Relay current setting
Relay time grading margin
Recommended grading margins
Calculation of phase fault overcurrent relay settings
Directional phase fault overcurrent relays
Ring mains
Earth fault protection
Directional earth fault overcurrent protection
Earth fault protection on insulated networks Earth fault protection on Petersen Coil
earthed networks
Examples of time and current grading
References
Current and Voltage Transformers
Introduction Electromagnetic voltage
transformers Capacitor voltage
transformers
Current transformers Novel instrument
transformers
  • پاسخ 112
protection
دانلود هندبوک شیرهای کنترل ویرایش سوم
  • 2 ماه بعد...
قبلا کتاب مرجع توربین بادی اریش هاو در پست
برای دانلود روی وبلاگ قرار گرفته بود که لینک دانلود اکسپایر شده است.بنا به درخواست تعدادی از دوستان کتاب مرجع توربین های بادی نوشته اریش هاو را مجددا وروی سرور پرشین گیگ برای استفاده دوستان اپلود نمودیم.
دانلود کتاب مرجع توربین های بادی نوشته اریش هاو
توربین باد مبانی،تکنولوژی ها ،کاربردها ومزایای اقتصادی ویرایش دوم
Wind Turbine
Fundamentals,Technologies,Application,Economics
Erich Hau
همراه با بیش از500 جدول ونمودار درزمینه تکنولوژی توربین های بادی واحداث نیروگاههای بادی یه عنوان یکی از دردسترس ترین منابع پاک وارزان انرژی
کتاب توربین های بادی نوشته اریش هاو را میتوانید از لینک زیر دریافت نمایید
حجم کتاب مرجع توربین های بادی 61 مگابایت میباشد
Wind Turbines: Fundamentals, Technologies, Application, Economics by Erich Hau Free Download
Wind Turbines addresses all those professionally involved in research, development, manufacture and operation of wind turbines. It provides a cross-disciplinary overview of modern wind turbine technology and an orientation in the associated technical, economic and environmental fields. It is based on the author's experience gained over decades designing wind energy converters with a major industrial manufacturer and, more recently, in technical consulting and in the planning of large wind park installations, with special attention to economics. The second edition accounts for the emerging concerns over increasing numbers of installed wind turbines. In particular, an important new chapter has been added which deals with offshore wind utilisation. All advanced chapters have been extensively revised and in some cases considerably extended
پسورد :
سلام بچه ها میشه لطفا این کتاب برام پیدا کنین.:w72:
lewis,optimal control.2nd
اگه حلشم دارین اونم لطف کنین خواهش میکنم.
:ws36:
:ws36:
دنباله ایناییی؟؟؟
دنباله ایناییی؟؟؟
مرسی دوست عزیز ولی اینا نیستن اسم کتاب همون optimal control هستش.:icon_gol:
optimal control lewis solution manual
دوستان این کتاب کنترل بهینه لوئیس حل تمیرنم داره؟ اگه هس اونم میشه لطف کنین؟:icon_redface:
  • 4 هفته بعد...
ممنون که کتابهاتونو در اختیار دیگران قرار میدید.
یه خواهشی دارم
آیا کتاب حل المسائل تکنیک پالس دیوید بل- محمود دیانی رو هم دارید؟ می تونید کمکم کنید پیداش کنم ؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟
  • 1 سال بعد...
دو کتاب نایاب و ارزشمند ماشین سنکرون
پسورد:
  • 10 ماه بعد...
سلام کسی کتابی سراغ دارهکه اموزش برنامه نویسی ofdm با متلب داشته باشه ؟
  • 5 ماه بعد...
کتاب آموزش نرم افزار logisim معماری کامپیوتر زبان اصلی
The Guide to Being a Logisim User
Logisim allows you to design and simulate digital circuits. It is intended as an
educational tool, to help you learn how circuits work.
To practice using Logisim, let's build a XOR circuit - that is, a circuit that takes two
inputs (which we'll call x and y) and outputs 1 if the inputs are the same and 0 if they are
different. The following truth table illustrates.
We might
