tashakore farvan az reza jan
  • 3 هفته بعد...
  • پاسخ 358
سلام من این مقاله رو میخوام از astm
Extension of a Stable Crack at a Variable Growth Step
Wnuk, MP
Visiting professor and professor, Technological Institute of Northwestern University, Evanston,Ill.
Mura, T
Pages: 32 Published: Jan 1983
اینم لینک دانلودش
با سلام ممنون می شم این دو مقاله رو در اختیارم بذارید:
1.
Simulation of mini/macro emulsion polymerizations. I: Development of the model
نویسندگان:
نام مجله:
ISSN
1992-1993, vol. 1, no1, pp. 75-109 (1 p.1/2)
لینک:
2.Simulation of mini/macro emulsion polymerization. II: Sensitivities and experimental comparison
نویسندگان:
نام مجله:
ISSN
1992-1993, vol. 1, no2, pp. 289-342 (24 ref.)
لینک:
با تشکر فراوان از زحماتتون
  • 3 هفته بعد...
1.Structure and mechanical properties of ultrafine-grained metals
Ruslan Z. Valiev
2.Superplasticity in nanostructured materials: New challenges
R.Z. Valiev, R.K. Islamgaliev and I.P. Semenova
3.
Influence of ECAP routes on the microstructure and properties of pure Ti
Vladimir V. Stolyarov, Y. Theodore Zhu, Igor V. Alexandrov, Terry C. Lowe and Ruslan Z. Valiev
4.
Processing of eutectic Zn–5% Al alloy by equal-channel angular pressing
Gencaga Purcek, Burhanettin S. Altan, Ibrahim Miskioglu and Pey H. Ooi
Ruslan Z. Valiev
3.
4.
all download
با سلام
نياز شديدي به دانلود اين مقاله دارم خواهشمند است در صورت دسترسي اين فايل را در دسترس قرار دهيد
Modeling of mechanical characteristics in hot deformation of 4130 steel
S.V. Sajadifar
, M. ketabchi and M. Nourani
Journal: steel research international
pages 934–939, August, 2011
ممنون از لطف شما
Influence of different cryotreatments on tribological behavior of 80CrMo12 5 cold work tool steel
K. Amini, S. Nategh and A. Shafyei
2.Effects of cryogenic treatment on wear behavior of D6 tool steel
A. Akhbarizadeh, A. Shafyei and M.A. Golozar
3.Effect of Cryogenic Treatment on Properties of Cr8-Type Cold Work Die Steel
Hong-xiao CHI, Dang-shen MA, Qi-long YONG, Li-zhi WU, Zhan-pu ZHANG and Yong-wei WANG
4.Effect of deep cryogenic treatment on wear resistance and tool life of M2 HSS drill
V. Firouzdor, E. Nejati and F. Khomamizadeh
منتظر باشید
all download
Automatic detection of epileptic seizures in EEG using discrete wavelet transform and approximate entropy
Hasan Ocak
2.Detection and diagnosis of bearing and cutting tool faults using hidden Markov models
Tony Boutros and Ming Liang
3.A novel data reduction method: Distance based data reduction and its application to classification of epileptiform EEG signals
Kemal Polat and Salih Güneş
4.Detection of machine failure: Hidden Markov Model approach
Allen H. Tai, Wai-Ki Ching and L.Y. Chan
Hasan Ocak
all download
  • 3 هفته بعد...
Effect of heat treatment on microstructures and tensile properties of Ni-base
superalloy M963
L.Z. He, Q. Zheng, X.F. Sun
2.Effects of cooling rate on the microstructure and mechanical properties of the Ni-base superalloy UDIMET 500
S.A. Sajjadi, H.R. Elahifar and H. Farhangi
3.Effect of Cooling Rate on Microstructure and Mechanical Properties of K465 Superalloy
Zhong-ye PEI, Wei HAN
4.Microstructure evolution of high-performance Ni-base superalloy GTD-111 with heat treatment parameters
S.A. Sajjadi, S.M. Zebarjad, R.I.L. Guthrie and M. Isac
superalloy M963
منتظر باشید.....
superalloy M963
دانلود......
آقا رضا یه دنیا ممنون. انشاالله هر چی از خدای میخوای بهت بده.:icon_gol:
سلام به دوستان متالوژ
اگر ممکنه در مورد موضوعات زیر راهنماییم کنید(البته ممکنه عناوین اشتباه باشه اگر عناوین صحیح رو هم بگید راحتتر جستجو می کنم )
1-استاندارد بالانس ISO 1940
2-aluminum key or aluminum hand book
3-خواص مکانیکی آلیاژهای آلومینیوم
4-هندبوک آلیاژهای مس
5-هندبوک بابیت
6-اسپری فلز
به این مقاله نیاز دارم(Van den Berg et al., 2002; Juneja et al.,1996; Singh et al.,1988)
5-هندبوک بابیت
6-اسپری فلز
به این بیا مطالب فکر میکنم بدردتت بخوره
The morphology and crystallography of lath
martensite
in alloy steels
S. Morito
, X. Huang
, T. Furuhara
, T. Maki
, N. Hansen
http://www.sciencedirect.com/science/article/pii/S1359645406005076
2.Morphology and substructure of lath martensites in dilute ZrNb alloys
D. Srivastava
, P. Mukhopadhyay
, S. Banerjee
, S. Ranganathan
  • 3 هفته بعد...
با سلام
کتاب innovation in electric arc furnace
ناشر springer
مولف yuri n. toulouevski & .....
