خط کش، متفاوت تر از آن چیزی که فکر می کنید!
constrained ball constrained ball is a drawing aid created by korean product designer giha woo. once attached to the pen, this device helps to draw straight lines without using a ruler. normally, a ball point pen rolls freely in accordance with the ball located at the tip of the pen. however, this writing tool prevents winding lines by helping to move the ball in one direction only. using the installed measuring wheel
indicated on the product, users can draw the exact desired line length in both a horizontal and vertical direction, as well as strokes in 45 degree angles. the mounting area is made with a flexible rubber material helping it adhere to the attached pen.measurement of line is indicated on the product[/size][/font]
:banel_smiley_4:
خیلی جالب بود
ولی واقعا خط راست میکشه !!؟
خیلی جالب بود
خب من كه هنوز امتحانش نكردم :ws3:
ولي به نظر منم مشكوكه چون ميتونه منحرف بشه ...
ولي شكل فيزيكي خواصي هم كه داره شايد بشه
آخه صلب طراحي شده و يه چرخ داره كه فقط در يه امتداد حركت ميكنه و دوران نداره
:ws52:
