HaMiD.CFD 20379 ارسال شده در 28 اسفند، 2010 آخرین نسخه این نرم افزار قدرتمند SolidWorks - computer-aided design, engineering analysis and manufacture of products of any complexity and purpose. SolidWorks is the core of an integrated set of enterprise automation, through which the support of the product life cycle, in accordance with the concept of CALS-technologies, including bi-directional data exchange with other Windows-based applications and the creation of online documentation. Consisting of the following versions and applications: - SolidWorks 2011 SP0.0 x32 Full Multilanguage Editions (2010) - SolidCAM 2010 SP2.0 HF2 German-English for SolidWorks 2007-2011. SolidWorks 2011 SP0.0 x32 Full Multilanguage Editions (2010) Depending on the class of tasks customers are three basic configuration: SolidWorks, SolidWorks Professional and SolidWorks Premium. SolidWorks is the CAD developer SolidWorks Corp. (USA), an independent subsidiary of Dassault Systemes (France) - a world leader in high-tech software. Development of SolidWorks Corp. characterized by high levels of quality, reliability and productivity, which in combination with qualified support SolidWorks makes the best decision for the industry. SolidWorks Integrated solutions based on advanced technologies of hybrid parametric modeling and a wide range of specialized modules. The software operates on Windows, and, accordingly, supports the Standard and ESKD. Ingredients: 1) SW2011_SP0.0_Win32_Full_Multilanguage.iso - the disk image to install SW2011 SP0.0 Win32 Edition 2) SW2011_SP0.0_Win64_Full_Multilanguage.iso - the disk image to install SW2011 SP0.0 Win64 Edition 3) SolidSQUAD.zip - medicine 4) SolidSQUAD.nfo - download the release notes Year: 2010 Version: 2011 SP0.0 Developer: DSS SolidWorks Corp Platform: Windows XP x86/x64, Windows Vista x86/x64, Windows 7 x86/x64 SolidCAM 2010 SP2.0 HF2 German-English for SolidWorks 2007-2011 SolidCAM - CAD/CAM system developed by a new generation of Israeli firm SolidCAM Ltd . This system is a complete solution for automating the production of metal. Using a wide range of proposed strategies SolidCAM turning, milling, turning, milling and electrical discharge machining process engineer can in a short time to prepare the necessary set of control programs for machining of the product. Functionality SolidCAM 2010 Support for 64bit computing due to the presence speuialnoy Edition SW 64bit 2.5-axis milling SolidCAM provides high efficiency and accuracy of the 2.5-axis milling parts. Supports different strategies for handling items such as contour, sampling (including islands) and a groove, as well as various types of hole machining: drilling, reaming, threading, etc. The system has a wide range of features 2,5-axis machining of analytic surfaces. 3-axis milling SolidCAM provides a wide range of tools that can be effectively used for treatment of products with complex geometry (dies, molds) and prismatic parts. As the geometry for a 3-axis machining using a three-dimensional surface or solid model. The system supports various types of strategies for roughing and finishing, such as the RIP with the specified or automatically determined by the angle of the raster processing of equidistant, the projection processing, handling at the waterline, etc. In addition to the listed capacity 2,5 - and 3-axis machining, SolidCAM provides tools to identify and refine areas not treated in previous transitions. You can create a database of typical technological processes. Once created, a parameterized process can be reused in the future, which significantly reduces the pre-production, improves the reliability of the developed programs, unifies the style of technological development, guarantees the use of only the best technologies for processing and ensures the independence of the production of the human factor. Lack zarezany guarantee the availability of means of control and visualization of machining. Multi-Processing SolidCAM provides various tools for creating control programs of the multi-processing of 4 - and 5-axis machining centers. The model is set in a user-plane processing, after which the system automatically calculates all necessary parameters for the displacement and rotation of zero items. As a result, significantly reduces set-up time of transition and increases accuracy. Lathes and milling SolidCAM has lots of features to automate the creation of control programs for turning and turning and milling. SolidCAM supports various types of tool that allows you to effectively perform longitudinal turning, facing, grooving, etc. In addition, SolidCAM automatically perform roughing and finishing of complex contours. Support rotating tool allows you to perform milling and drilling transitions to processing centers. Spark erosion The proposed set of strategies SolidCAM Wire EDM allows processing of external and internal contours of constant and variable angle. The possibility of 4-axis machining. Special algorithm to prevent the fall of the treated material. SolidCAM provides the user with a means for controlling the physical parameters of the processing on the entire trajectory of the wire. System requirements: pre-SolidWorks 2007-2011 32bit/64bit Version: SP2 HF2 Developer: SolidCAM Ltd Bit depth: 32bit 64bit Compatibility with Vista: complete Compatible with Windows 7: complete Language: English & German Download: SolidWorks 2011 SP0.0 x86: برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام SolidWorks 2011 SP0.0 x64: برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام 2
ارسالهای توصیه شده
