Peyman 16,150 اشتراک گذاری ارسال شده در 5 تیر، ۱۳۸۹ Some examples of welding discontinuities are shown below. Evaluation of the discontinuity will determine if the discontinuity is a defect or an acceptable condition: Incomplete Fusion - A weld discontinuity in which fusion did not occur between weld metal and fusion faces or adjoining weld beads. برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام Undercut - A groove melted into the base metal adjacent to the weld toe or weld root and left unfilled by weld metal. Overlap - The protrusion of weld metal beyond the weld toe or weld root. برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام Underfill - A condition in which the weld face or root surface extends below the adjacent surface of the base metal. Incomplete Joint Penetration - A joint root condition in a groove weld in which weld metal does not extend through the joint thickness Partial joint penetration groove welds are commonly specified in lowly loaded structures. However, incomplete joint penetration when a full penetration joint is required, as depicted above, would be cause for rejection. A fix for an incomplete penetration joint would be to back gouge and weld from the other side. Another acceptable partial penetration joint is shown below. برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام Partial penetration joint on the left without discontinuities is an acceptable condition where appropriate. Appropriate engineering decisions need to be applied to determine what type of joint should be specified for a given application. Engineering should be contacted to determine whether partial penetration of full penetration joints are appropriate for a particular situation. برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام Above are several different representations of weld Cracking برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام Below is a representation of a convex fillet weld without discontinuities. If your company is experiencing these or other welding problems you can retain AMC to improve your weld processing. Hire AMC to act as your welding specialist برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام . 3 نقل قول لینک به دیدگاه
pesare shad 1,097 اشتراک گذاری ارسال شده در 9 تیر، ۱۳۸۹ بررسی ناپیوستگی معین میکند که ناپیوستگی حالت قابل قبول و یا عیب است. under fill عدم پر شدگی – یک حالتی که در سطح جوش یا سطح ریشه جوش بصورت فرو رفتگی کناره سطح جوش نسبت به فلز پایه lop or lake fo penetratoin or Incomplete Joint Penetration نفوذ ناقص – در اتصال ریشه جوش در یک شیار جوش که فلز جوش کاملا" بین ضخامت جوش کسنرش پیدا نکرده است. under cut بریدگی کناره – یک شیار ذوب شده داخل فلز پایه در مجاورت پای جوش یا ریشه جوش و عدم پرشدگی با فلز جوش. over lap افتادگی جوش (سر رفتگی جوش) – پیش افتادگی فلز جوش خارج از پای جوش یا ریشه جوش. Incomplete Fusion or lake of fusion or lof ذوب ناقص {عدم ذوب} - یک ناپیوستگی جوش که عدم ذوب بین فلز جوش و سطح مذاب یا سطوح مهره های جوش کنار هم اتفاق می افتد. crack ترک - که در تمامی نقاط یک قطعه امکان روی دادن آن می باشد و به دلایل مختلف که از جمله این دلایل وجود فرآیند جوشکاری می باشد. معمولا" عیوب بر اساس استاندارهای مختلفی (مثل ASME یا AWS ویا DIN و ...) بسته به نوع بار اعمالی بر روی قطعه یا طراحی آن و یا کاربرد و ... بررسی میشوند و در صورت واقع شدن در محدوده پذیرش این استانداردها از اعتبار ساقط می شوند و دیگر عیب بحرانی محسوب نمی شوند. 2 نقل قول لینک به دیدگاه
pesare shad 1,097 اشتراک گذاری ارسال شده در 9 تیر، ۱۳۸۹ در یک پروژه امکان رخ دادن عیب به طور حتمی وجود دارد بنابراین با داشتن دستورالعمل ساخت،دستورالعمل جوشکاری WPS و معیارهای عیوب در استاندارها و بازرسی دقیق و ملاحضات اقتصادی می توان به تعمیر جوشها بدون ایجاد هر گونه مشکلی فایق آمد. عیب چیست : در جوشکاری رعایت نکردن بعضی از اصول سبب کاهش استحکام جوش می شود که نتیجه آن عیب می باشد. جوش معیوب: جوشی که یکی یا همه نیازهای مطرح شده در استاندارد یا کد مرجع را دارا نباشد جوش معیوب تلقی می شود. انواع عیوب معروف در جوشکاری عبارتند از: *پروفیل نامناسب جوش (Bad Profile) *تخلخل (حفرهPorosity) *ترک (Crack) *تقعر (Concavity) *تحدب (Convexity) *جرقه (Spater) *لکه قوس (Arc Stricke) *رویهم افتادگی لبه (Over Lap) *سوختگی سراسری (Burn Through) *عدم ذوب کافی (Lack of Fusion) *عدم نفوذ کافی (Lack of Penetration) *عدم هم ترازی (High-Low) *نفوذ بیش ازحد (Exesses Peneteration) *سرباره حبس شده (Slag Inclusion) *بریدگی کنار جوش (Under Cut) *چاله سیاه جوش (Black Point) *تنگستن حبس شده (Tungstan Inclusion) *عدم پرشدگی شیار (Under Fill) *گرده اضافی درجوشهای شیاری (Weld Reinforcement) *تورق (Lamination) *عیوب فلز پایه درحین فولاد سازی (Seam/Lap) *بازشدن دو پوستگی ( Delamination ) *مشکلات ابعادی (Dimensional) 2 نقل قول لینک به دیدگاه
pesare shad 1,097 اشتراک گذاری ارسال شده در 17 تیر، ۱۳۸۹ سلام دوستان عزیزم اینم یه فایل باحال و فوق العاده کارآمد با توضیح توسط عکس های شماتیک و عکسهای رادیگرافی شده از عیوب جوش. امیدوارم به دردتون بخوره و شاد باشید. در ضمن اگه پسورد خواست از PESARE SHAD با حروف بزرگ استفاده کنید. برای مشاهده این محتوا لطفاً ثبت نام کنید یا وارد شوید. ورود یا ثبت نام 2 نقل قول لینک به دیدگاه
به گفتگو بپیوندید
